The connection is getting disconnected too often on laptop (win xp) - It just either stops ransferring bits or hangs after 5-10 mins of connection. Sometimes it does not get connected also. When I re-boot the laptop, it gets connected sometimes./quote]
If you are using PPPoE,then try to inscrease the Keep Alive from 10 min to a greater number.If that doesn't work the modem needs to be patched
