Hello:
I have problem. I recently got my BSNL BB and using Beetel 220x. Big thanks for your detailed note on how to setup. after following the instruction belowis what I have setting for my wan. I have connected line to
ADSL modem which outputs to my Belikin Wireless
router and at my
laptop using wirelessly to connect (even tried direct from modem to laptop same issue). Now the problem comes. Ping to any domain from cmd prompt works fine. I see reply responses but when I try opening the same domain in brower it wont. Only site works to me
www.bsnl.co.in
Please help. I am using Vista. I found something related to it on
Microsoft site and copied that info at very bottom. I am frustated as I am getting no where from past 3 days
. any help in this would be
much much appriciated. Thanks
Mahen
Device Info
Board ID: 96338L-2M-8M
Software Version: 3.00L.03.A2pB017l.d15h
Bootloader (CFE) Version: 1.0.37-0.7
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 861
Line Rate - Downstream (Kbps): 2046
LAN IP Address: 192.168.1.1
Default Gateway: 117.195.160.1
Primary
DNS Server: 218.248.240.46
Secondary DNS Server: 218.248.240.79
WAN Info
VPI/VCI Con. ID Category Service Interface Protocol Igmp QoS State Status IP Address
0/35 1 UBR DataOne ppp_0_35_1 PPPoE Disabled Disabled Enabled Up 117.195.160.191
DataOne Diagnostics (results)
Test your Ethernet Connection: PASS
Test your USB Connection: DOWN (not using USB anyways so no issues)
Test the connection to your DSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping: PASS
Test ATM OAM F5 end-to-end ping: PASS
Test the connection to your Internet service provider
Test PPP server connection: PASS
Test authentication with ISP: PASS
Test the assigned IP address: PASS
Ping default gateway: PASS
Ping primary Domain Name Server: PASS
Vista settnigs recommended on microsoft help
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{GUID}
In this registry path, click the (GUID) subkey that corresponds to the network
adapter that is connected to the network.
On the Edit menu, point to New, and then click DWORD (32-bit) Value.
In the New Value #1 box, type DhcpConnEnableBcastFlagToggle, and then press ENTER.
Right-click DhcpConnEnableBcastFlagToggle, and then click Modify.
In the Value data box, type 1, and then click OK.
Close Registry Editor.
Hello:
setting for my wan. I have connected line to ADSL modem which outputs to my Belikin
Wireless router and at my laptop using wirelessly to connect.
to me
www.bsnl.co.in
Please help. I am using Vista. I found something related to it on Microsoft site and
Thanks
Mahen
Device Info
Primary DNS Server: 218.248.240.46
WAN Info
