@farukh9090
please see this thread and post your replies there.
https://broadband.forum/bsnl-dataone-broadband/18979-bsnl-broadband-my-web-pages-loads-up-way-slow/
Quote
Error 718 indicates a PPP conversation was started, but was terminated because the remote server did not respond within an appropriate time. This can be caused by poor line quality or a problem with the server (ISP). This error can occur when your modem has connected to the ISP and has sent username and password, but there is no response from the server. Sometimes, re-dialing will be successful.
Error 718 can also occur if your ISP account has expired, or if the username or password you are using is invalid. Error 718 can occur if you have LCP extensions enabled in the TCP/IP Properties of the connectoid and your ISP does not support LCP extensions.
Error 718 may also occur if you have one or more network cards in your machine, and the cards do not have TCP/IP protocol enabled, or if the TCP/IP settings are incorrect. (Go to Networking in Control Panel to examine the properties of your network adapters; or, if you are not using the network card(s), disable them in Control Panel->System->Hardware.)
Unquote
@niknis I am also blinking !
Checked in
Google search, and found it is meant for newsgroups etc.
giving Port number ( akin to SMTP) . did you try in your email program OE or Outlook ?
Lost interest !
