well basically,i bought the damn thing and it sux.i live in cochin and the speed sux big time and i live like 2 kms from the city,and the signal strength is always shown as full strength,so weak strength is not an issue.the max i've ever done is 1mbps.and that happened when i was sitting inside the bsnl office complainin bout the poor speeds:S.i get only 0-100kbps 95% of the time.and speed flexes A LOT!!!one second it'll be 400 or 500 kbps(when i'm lucky) and the nxt second i'll b getting 50kbps.another problem is that when i'm downloadin via utorrent and not browsing,the speed goes to zero,and stays there!! its only been 2 weeks since i got this thing and i,for one,am done with it:frown:!!!not like i can get rid of it either,i BOUGHT THE DAMN THING!!!so long story short,my advice to ppl wantin to buy the evdo thingy-this thing works in some places,and in some places only,so dont go out and buy the thing,rent it out first,try it out all over your house,and then if it works well,go purchase it outright(yeah you can purchase it after renting it first).remember,whatever happens,DO NOT BUY IT BEFORE RENTING IT OUT AND TRYING IT OUT AT HOME.trust me,i regret wasting 3.6g on this thing.
