In cmd and copy paste the results. Are you sure, you havent enabled mac address control in your router ? Click on mac address filter link on your router's page, take a screen shot and post it here.
use windows 7 64bit
Click the Wifi icon. context menu select Status
page opens
Say shows Not connected ( first entry )
click "diagnose"
follow instructions
may connect or give an error message.
report here.
hi
finally it worked. what i did was just restarted both my laptop and computer. reboot 192.168.1.1.
thanks a ton to "essbebe" and "x720".
my new question is how to add more security to my wifi connection? like password?
thanks again
hi
i use Nokia 5800. i cant access wifi in dat. any suggestions??
wifi network "BSNL_AP" is detected.
unable to see my mac address my mac address is 00-00-00-00-00-00-00-EQ which is invalid so how can i get my mac adress of laptop which is valid
Dear Friend
Actually you do not need to follow MAC ADDRESS Step you can skip it or leave the space blank. I did the same and am successfully using my two laptops and one Desktop PC(with USB WIFI TXRX Module) since last six months
