You can use the SAME modem to connect another computer to internet
Modem USB Port to computer USB port.
( rarely used )
Additional drivers are needed. If you have installation CD, confirm.
Thanks for your response, the USB port in the modem does not look like the usual port in all the modems.
it is a simple USB port where I can insert a USB stick. I tried connecting my external network HDD to it.
The port is a USB port not the Square USB which is found in all the modems.
I will take a picture of it when I am at the modem and post it.
Do you mean to say that I need a A/A USB cable ? Normal modems need A/B USB cables to connect.
IF we try to use A/A cable between two computers, we may end up burning the USB ports or even the power supplies. Same case here both MODEM and PC will be supplying power in their respective ports.
