1. Ok for laptop on lan mode, directly connected to BSNL Modem
Code:
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
DHCP Enabled. . . . . . . . . . . : Yes
Description . . . . . . . . . . . : Generic Marvell Yukon 88E8057 PCI-E Gigabit Ethernet
2. Yes, my BSNL modem page looks exactly like the one you have shown in the picture.
PROBLEM UPdate
yes, on only one laptop, i can wirelessly connect to the network.
The network shows up on the other desktop but can not connect to it using the same
password/WPA-PSK wireless settings as the laptop.
Ok.
(A)confirm Second 2nd system is desktop or laptop.
Connect in lan mode and also check wifi mode.
(B) if needed.
Back to NetgearWGR614 settings. .
Check under Advanced settings .
Wireless. confirm Access list is NOT enabled.
Details of systems allowed not listed./filled up.
feedback.
