Consolidated Problems Faced By Reliance Jio AirFibre Users
  • Thread starter Thread starter rohit267
  • Replies Replies 31
  • Views Views 8,329
  • Locked down router
  • Cannot enable Bridge Mode
  • Cannot disable WiFi
  • Cannot have different SSIDs for 2.4Ghz and 5Ghz
  • Cannot change WiFi bands.
  • Cannot ban connected devices
  • Huge Packet loss during evenings
  • Router has memory leak issues, memory usage goes to 96% and router starts dropping connections and internet stops working on connected devices.
  • No Option to manually check for Firmware updates.
@rohit267 We have an option to set the SSID in the myjio app. Did you try to use to set a different SSID for 2.4 and 5GHz.? Jio is using tr69 application for router management and it seems have a problem syncing back settings done in the router. I haven’t tried it but atleast there is an option with the drop down.
Bruh, they came and after lot's of troubleshooting came to know only wifi has packet loss issue but not on ethernet, they replaced the router with new router with old 1.7.2 firmware which did not had packet loss issue at least. After few hours, router updated itself to 1.9.1 and the problems are back.
So it's the faulty firmware which is causing issue not the hardware or backend.
@rohit267 - I need help with Jio Air Fiber I got a connection with a speed of 300 MBPS however it has never gone beyond 100 Mbps. made numerous calls to the cc team but they are dumb TBH. No technician visits except one who visited yesterday after 100th call.
The technician verified the below things
1) The ODU unit was connected with a CAT5e cable (approx 50mts) to the router which he mentioned is the wrong cable and we need to try a CAT 6 shorter cable. So we did and the results were the same.
2)Before the technician's visit we tried different devices/websites to check the speeds and the same issues.
3)Tried via LAN too and the situation remains the same.
4) The technician mentioned that the signals from the tower to ODU is fine.
5)I am losing pings in between the games
6) Sudden drops in speeds when in meetings
@vinkz93 Their technicians are useless.
You can't do anything about ping and packet loss.
However, you try one thing if you have Jio5G sim in your mobile.
Place it the same place around the ODU and do a speed test, use NetVelocity/NetMonster apps and take measurements of the SNIR/SNR value.
Find a place where SNIR is strong enough to give you 300mbps.
Place the ODU there.
@rohit267 I checked things as you suggested
It’s a round-shaped ODU and I see there are two installed in my buildings.
1) I checked the signal at my ODU it was good however the quality was Bad (In Red). In my OnePlus Jio 5g SIM, the download speeds were going up to 200 MPS and Uploads hovered around 150 MBPS.
2) Then I went to another ODU installed at another side of the building and surprisingly the quality in the app showed as average. (In Amber) and the speed clocked 350+ MBPS in three different speed tests in OOKLA & Net velocity.
Seems I only need to ask these technicians to hook the RJ 45 from my ODU to the already installed ODU as it has switch ports too for other users. Or I may have to ask them to find a much better spot.
Any other things I can try?
@Surajgowda - Yes i have a Round ODU
I am unable to attach pics in the reply so added pics in G Drive have a look.
Speed tests – Google Drive
@vinkz93 you seeing that SS SNR in net monster app, that should be above 9. You can also get this value by enabling Advanced mode in NetVelocity app
Well lemme add my two cents here, i have been a new customer for jio airfiber for past three weeks, so far pretty good. Except some caveats which i expected as everyone on discussion forums was going crazy about them. Apparantly I didn't face any packet losses(yet) , my home is fairly big approx 3bhk, having router in one end of the centre alleyway.
The connection at horizontal diagonals to the router are pretty weak, wall penetration is okish?? It covers almost my entire house with few dead spots at the corner. Lucky for my the tower is just 50m away from my house
The router is pretty much locked, faced some disconnection. As for doing interception of the requests it's too much of a risk i would be taking if the damm thing stops working (⁠T⁠T⁠)
My current version no is GMOBJIO_JIDU6801_R1.9.1
