Converting existing telephone wires to Ethernet cable
  • Thread starter Thread starter vNa5h
  • Replies Replies 21
  • Views Views 11,340
Is there any way we can convert normal cat 3 four wires telephone cable to Ethernet cable...
I need my existing secondary concealed telephone wiring as a LAN cable
AFA I researched 4 wire can support upto 2 mbps only..
Also couldn't find any rj11 to 45 converter..
So crimping needs to be done I guess
Has anybody tried this..
Or any inputs regarding the feasibility
Not possible.
Cat 3 = 2 pair
Ethernet cable (Cat5/5e/6) = 4 pair.
Not possible.
Cat 3 = 2 pair
Incorrect !
Cat3 = 4 pairs = 8 wires
Cat3 = 4 pairs = 1st gen ethernet cable that supports 10mbps till 100 mtrs.
technically, upto 100 mpbs ethernet uses 2 pairs out of 4. But if you have a category 3 written on the cable then it is 4 pairs only, maybe the guy who crimped it just terminated 2 pairs for phone application and discarded 2. You just need to change the RJ11 connector to RJ45 on both sides.
Incorrect !
It has four wires.. Two pairs.. Doesnt seem like a twisted pair.. The wires are separate..
But won't it need crimping
LAN connection needs total 4 wires.
One for read and one for write for each end.
So for two ends - total 4 wires.
All you have to make sure is that proper crimping is done with proper color. But may not be easy
See this image, when you crimp, let unused areas have NO wire.
Rest of areas use same colors at both end.
Its not necessary that you need exact same colors as in image below.
Colors are standardized just to make sure there is no confusion in future.
You can try, but keep in mind that the signal/bandwidth will have a massive drop from room to room using this '4 wire' cable. Ethernet cables have more twists to improve signal/bandwidth.
If it works, then nothing like it. If it does not work, then wifi is an option.
