can i expect a similar extention for IE 7???
just curious
thanks
Not trying a conversion here (people can be very religious about the browser they use. I am.). But don't you think it would be easier to use the ie-within-firefox addon and get the benefits of both ie and this plugin at the same time?
I have no luck with Datafox even though it installed and run ok. The trouble if it won't login to bataone to check usage. I have tried all the possible IP address suggested. It behaves as if BSNL is blocking it. The same login name Password etc works ok to manually login at Dataone SSG.Can any one help?
Sudharma,
DataFox has been working just fine all this while, not sure what the problem might be. I don't think BSNL is blocking it specifically, I'd have heard many more reports of it failing :)
I'm currently using 10.240.89.199 and it's working fine (I assume these work all over India). Your username should be "xyz" and not "xyz@dataone...".
What you could do is enable the debug mode in DataFox. Here are the steps:
1) In your address bar, type "about:config"
2) Key in "datafox.debug.active" in the filter box
3) Change that property to true
4) Open your Error Console (Tools > Error Console)
5) Clear the console and attempt to check details with DataFox, tell me what it says; you can paste it here or email me at infernalproteus@gmail.com
Note: Try not to do anything else while attempting to check your usage with datafox, that will ensure no noise from other pages being loaded gets into the logs.
Hope this helps,
Brian.
for sudharma99... i think it is the problem with the ip address,,what u can do is first manually open login page to the portal(no need to login),,then look at the address bar and copy the ip address(only ip add part) mentioned..and use that one in the datafox override default domain.. hope this will solve the problem non of the default ip mentioned worked for me, i used the above method worked for me... pls post result if it worked or not
@saurav_wow It will be helpful if you mention the IP you used. So that it can be entered in the DataFox Program. Logging to BSNL, and then DATAFOX is not ideal. I get the usage result above the task bar without any problem.
i was trying to help Sudharma for his problem,,in his case my ip will not help him,that is what i think..
logging to bsnl was just to help him retrive the ip that he should use with datafox,if u had read carefully...
Can any one help?
please read the above 3 posts.,..
Just wanted to point out that if you do not choose the "override IP" option, DataFox will use a similar technique internally to get the right IP for you. I don't have the code at hand right now, but IIRC I check sancharnet.in which will redirect you to an IP based on your location, DataFox will then proceed to use this IP for the remainder of your Firefox session. Of course, if you override the IP, that address is used directly.
Doesn't help our current situation with sudharma, but thought you guys might enjoy some "internals" :)
Brian.
@saurav_wow
No problem. If a "bug" is noticed in a program unless we give full details the programmer cannot check/ update it. The interest is the site , other than six listed in the DATAFOX program. IP address of DATAONE usage check , you mentioned. In the program following IP's can be selected.
10.240.144.195
10.240.240.195
10.240.89.199
10.240.43.16
10.240.16.195
10.240.0.195
Para two : Direct checking http://10.240.0.195/webLogin.jsp already included above
