i use the following ip10.240.112.195hope it helps....ps:well i dont remember what was the error message,but i didnt get the updated usage in datafox until i override the ip with the above..
to the programmer of DATAFOXcan u make a program or even modify datafox, that helps monitor the login/logout time at the portal and compare that with the local login/logout time..in that way you can sort out the time sync problem to some extent..ps:this is just an idea,and i am not a programmer,so dont mind if i sound stupid....
No issues - I was thinking of a way in which I could use DataFox to help with this situation myself.
The primary issue is - DataFox stops when you close your last Firefox window - which does not mean you are logged out. You can logout in multiple ways; turning off your modem, disconnecting your PPP dialer, asking your router to disconnect, problem on the line, server... who knows. So the only way for DataFox to know you're logged out would be if DataFox could initiate the logout itself - and this is non-trivial. There are other tricker ways, but these are not really user friendly.
Now when you log back in, you must start DataFox, so it can look at the time as recorded by BSNL. The problems here are
a) BSNL might have not even added this record yet (in my experience, usage records are not added immediately)
b) You must start DataFox when you login next (even if you only wanted to use MSN to chat), or DF will look at the wrong record when you do start Firefox (if started in another session)
Any ideas?
Brian.
Are you making one?I would if it would help the situation; though now not constrained by FF, the program must still initiate the disconnect and it must know when you're online again so it can go check you records. The record issues I mentioned above still exist. To figure out if you're online or offline, you can either a) tell the program (or tell the program you "intend to")b) have it try and find out by pinging or something similar (my router will go ahead and initiate a connection if offline in this case)c) [if there is another foolproof way, let me know]To recap, writing a standalone program only removes one of the smallest obstacles.Brian.
i was going to suggest for a standalone program...if you r gonna write a standalone program...i suggest a program that will be able to monitor the local area connection(especially dataone) and make a log(local log) of the connection/disconnection time as per the local computer..and then which will be able to retrive the online log/record as per bsnl and then compare it with the locally created logand then be able to tell the difference..which may be stated as "timing difference for the last session"only problem is that it will be based on the last session timing..another problem with this method will arise due to the lag in updating records in bsnl..so when someone logsout and the logsin within a few minutes then the time difference will not be accurate as the online record for the last session is not updated..in that case the program should compare the latest available record (as per online log ) with last 1-4 records of the local log and give the difference which is the least...i hope u understand what i am trying to say...this is just a suggestion,hope it helps..
iam not able 2 use datafox..the prob is i cant log on 2 any of IP's in datafox even thro my browser..the ip which works 4 me is::10.0.0.38:8080 ..when i input this ip in datafox and tries to login,it fails..can any1 help me out??
