DataFox 1.4 has finally arrived. Here are the noteworthy mentions:
1) Restored Firefox 3 support, tested with FF 3 beta 5.
2) Support for bbservice.bsnl.in.
3) DataFox will now cache the last details fetched.
bbservice.bsnl.in users are hereby advised that depending on the frequency of use, the usage records could actually grow past a megabyte in size; every time you check your usage, you would "use" that much of your bandwidth. DataFox would use nearly as much as you would use by visiting the site directly.
The above issue forced my hand on the cache support which I had been putting off. If "login on startup" is unchecked, DF will display the last fetched details on startup, until you explicitly ask it to update. If the update fails for some reason (server down, connection issues, etc.) then you can press CTRL and click the status bar icon at any time to revert to the cached values. Cached data is shown in grey (customizable on the preference page). Hope you guys find this useful.
Users who have DataFox installed can just go to Tools > Addons > DataFox, right click and select Update to initiate the update process.
New users, click the "install now" button here:
DataFox - A BSNL DataOne & MTNL TriBand bandwidth usage monitor
Would like to specially thank Sunish, essbebe and mbgupta for making support for the new bbservice portal possible. :thumbsup:
Looking forward to your feedback, I'm watching
Brian.
