@/members/boygr8/You can download the present version. The day it is released yours, will be probably automatically updated ! Get the feel now. I have switched to Minefield fully, after Datafox1.4 update accepted by the browser. .May delete fully FF 2.0.0.13 after some time.
@Brian : thanks for the help.
I did as u suggested and here are some screenies.
this is the login screen :
http://img218.imageshack.us/img218/4648/datafoxloginkc1.jpg
I'm getting the same error :
DataFox: Error logging in, please check your username, password & domain.
and this is the error-console screenshot :
http://img218.imageshack.us/img218/2872/datafoxerrorlogps4.jpg
and this is what I get when I login manually using the Portal ID :
http://img359.imageshack.us/my.php?image=shotak7.jpg
I'll wait and see if other users who use ( BSNL - Broadband Account Management ) to check their usage and have the new ip range 117.*.*.* are able to use DataFox 1.4
Argus,
You are not using DataFox 1.4, this version prints out the version number instead of "DataFox Starting up" which I see in your log.
You can go to Tools > Add ons and select DataFox in the list, you should see the version on the right. Right click, choose "Find Update" and install the update, restart Firefox (you need to close all windows) to get the new extension.
Can you tell me how you attempted to install 1.4 in the first place?
Thanks,
Brian.
^^ Bingo !
It seems that the link to DF 1.4 at the top of the page (DataFox - A BSNL DataOne & MTNL TriBand bandwidth usage monitor) is actually linked to the older version (datafox-1_0_1.xpi).
screenshot : http://img217.imageshack.us/my.php?image=datafoxabsnldataonemtnlqd5.jpg
(look for red circles)
Found the correct link to DF 1.4 at the bottom of the page and it runs fine. I really appreciate your fine work for the community. Repped ++ :)
Argus,That was a pretty bad oversight on my part, thanks for pointing it out, I've corrected the link. Glad it's working for you now and thanks for following through.Brian
@ Brian Great addon...........one of the reasons why i've switched to firefox.....:yahoo:keep it up.........expecting a lot from you.....
Thanks for the updated version supporting FF3 :yahoo:
