:( do you think its cool to get the data from those records...?I mean the whole point of the local bandwidth meter is to tap the outgoing data and not to get data from bsnl server.../:-|Im workin on that meter basically cause bsnl is too slow to add the current record into its db...its bit misleading...accn me...whats the use if your db reports data 2-5 hrs old...Im just not sure what happens to the error frames that we recieve..are they counted as legitimate data frames (for measuring usage ) or not...
/members/sunnyhipe/
Datafox addon works with all the ater versions of
FireFoxThe new version 1.4 /al is meant/modified for users having IP 117.xx.xx.xx.
I am using FF 3.0so in Minefield which is the latest and Datafox is working as an addon.
I have to use 56 MB by midnight ( free 1GB= 1024 MB), as shown by Datafox now !!!
@/members/-nikhilelite-/ Welcome to Broadbandforum.in
If you mean from BSNL usage portals, the usage data is what is FINAL and basis for calculating your BB monthly bill !!!!and final. ( errors or no errors )
Para two :
A program like DataFox is also need for IE users. It will be better if you can give a
Usage meter like DF for use in IE as well as Opera browsers.
Im just not sure what happens to the error frames that we receive{/quote]
You can check it with Shaplus 1.1.
Please see post 234 ( link given )above for a partial list of often used free programs available for checking bandwidth . usage.
DF is actually getin those records from server...I don't think it makes sense to do it that way....
what we need is a tool that sits between our nic and mesures just the speed data etc...
Im using .net...
yeah and the tool will be similar to that du meter...except I will provide some options for costing :P just for tp...no tech value to it though...
Im using .net...
yeah and the tool will be similar to that du meter...except I will provide some options for costing just for tp...no tech value to it though...
DF is perfect coz it shows you what BSNL is recording for your usage. That's the bill you are going to get. Not what your local software tools tell you.
I don't trust that...and I want to do a tool that actually shows the diffrence... man and I don't want a tool that consumes bandwidth to show whats the bandwidth
@https://broadband.forum/members/-nikhilelite-/
https://broadband.forum/bsnl-broadband/22290-bsnl-broadband-billing-problems/#post184528 page 7 post 69. A partial list .
Using any usage meter is left to the user. Using DataFox is optional.
To be accepted as an Addon by Mozilla, is itself a great honour .The programmer(FF addict ) is very busy and politely refused a similar program for IE.
You can make a similar one with all the improvements, you feel should be there for IE/opera users..
At least read the thread last 10 or 15 posts.
Update: Just now Datafox usage 47 KB for updating data .
Could be more when clicked at start up.
heh have fun dealing with BSNL asking them not to charge you for the difference in calculations between their usage data annd your own. :whistle:
The purpose of DataFox as pointed out above is to help users figure out where you stand from BSNL's point of view. If you tell them, "bandwidth program XYZ" said I used only 5GB, but their records say otherwise, no prizes for guessing what they are going to believe. What you trust is irrelevant, unfortunately; at least from a billing point of view.
So, I beg your pardon, but it makes perfect sense according to tens of thousands of existing users, and to me. I admit that it would be nice if BSNL recorded details more frequently, that is already happening for the newer portal and hopefully improvements in the newer portal will help reduce consumption even further. (@essbebe, thanks for the figure :))
A bandwidth meter is always a useful tool, and with your costing additions, perhaps it will show you what the cost should be, but may not show you want the cost will be. Remember that these solutions prove to be a tad more complex once you have more than one computer behind a router for instance, or perhaps if you switch to an OS on which the app is N/A.
Regards and good luck.
Brian
@Brian - Thank you very much for providing this great tool. I have been enjoying it for the last six months or so. :thumbsup:
I have a couple of obervations about how BSNL seems to be displaying data and calculating the usage. I would like to know if anyone else has
a similar experience or if I am mistaken in my observation/conclusion.
1. I noticed that when I refresh DF, it does not show the latest usage till some time after I log off and back on on my DSL modem. That is, BSNL seems to be providing information only after the "session" ends. This seems a bit strange to me because I am used to Sify's way, where, if I am not mistaken, I did not have to log off/on to see my data usage.
2. I try to make as much use of the 2 am to 8 am unlimited downloads.
I noticed that if I have a download that extends past 8 am, then the usage is not accurate. Say, my DL (download) ends at 8.10 am, then I would expect only to be charged for the usage during those 10 minutes. But I think I am charged much more than that. Not only that, I think even if my DL does not extend past 8 am, but I don't end my session at 8 am (ie log off and on), somehow a part of what I DL'd before 8 am shows up as my usage for chargeable transfer. Has anyone else seen this?
Thanks
