lol! why go to any other os...your tool needs firefox to run on.... what if the user uses another browser,or lets say he doesn't use a gui browser at all....what then...?lets say I make heavy use then what... ?if your program is more restricted than os dependant programs, what good does it do you?use of torrents :|
os dependent program? firefox comes on all the popular os platforms... datafox is one of the many tools you can use to check your bandwidth usage. the main advantage is that you get to see the usage 'recorded by the ISP' that you are going to pay for. as simple as that.
duh. your alternative is to install a BRAND NEW PROGRAM to check usage! and keeping it running to measure your bandwidth usage. while this adds on to firefox 'IF' you use it. you do not have to keep running it to keep the measurement accurate. you just get a quick glimpse of the data if and when you need it.
umm. datafox is not a tool to measure speeds... :Sit is a tool to show the bandwidth usage 'as recorded' by bsnl/mtnl. just that.
ohh..sorry then..but I need speed to...cause I suspect bsnl decrease speed as we go on using the connection ...so that timexData remains constant...
Short SUMMARY for "Antakshri users "!!! From Post No 241 to 256
Extracts:
@members/-nikhilelite-/
Post 241 DF is actually getin those records from server...I don't think it makes sense to do it that way....
pOST 243
man and I don't want a tool that consumes bandwidth to show whats the bandwidth
Post 249 lets say I make heavy use then what... ?
post 251 Im saying what if you use other programs ...? then what...
@/members/essbebe/
You can make a similar one with all the improvements, you feel should be there for IE/opera users..
By the programmer @infernalproteus.
Post 247 The purpose of DataFox as pointed out above is to help users figure out where you stand from BSNL's point of view.
@ sushubh umm. datafox is not a tool to measure speeds...
Get your objective clear.
A) find "bugs" in FireFox
B) prepare a new program avoiding short comings(?)in FireFox
C) Challenge BSNL about usage calculations.
D)Specify how a Bandwidth meter usage should work.
E)Simply argue without any point/s
Para two :
Dont mix
a)OS/Programs/Applications/Usage meters/Bandwidth meters/ BSNL/DATAFOX.
b)This thread is for DATAFOX application .
c)You are welcome ( others too) to give an ALL PURPOSE program or similar program for other browsers.
d) Browsers:To start with IE7 or IE8. ( DQUF/QUF/Shawplus etc available ) Then for Opera
e) ISP: For BSNL ( for IPs 117.xx.xx.xx and Ip 59.xx.xx.xx/Then MTNL Mumbai//Then MTNL Delhi
Then for other ISPs.
f) Operating Systems: I am stuck with XP pro sp2 as a user. Unable to try other OS. Do not know any other OS.
Unable to comment.
im here for time pass... and seeing if theres anything new...nothing more...
Dataone Bandwidth Monitoring Extension For Firefox
if you were so precise...why give this title...
its no where near b/w "monitoring" as such
Thank you , for an honest admission that you have nothing to contribute. . You have deprived/delayed others with genuine problems,who use IBF, a solution to their problems, by spending time on this thread. .
Please start a new thread "Timepass" in any other subforums.
As a special case you can suggest an appropriate title. We will request @Admin ( Sushubh ) or moderator/s to move all posts.
starting with your comments at 241 to 257.
