@/members/joe2005/What is the version of FireFox you are using ? ( will work on all versions )Go to Tools Addons and select Datafox. Uninstall. Close FF and reload. Or see whether it has been enabled. Select latest version 1.4.
members/gary4gar/
BSNL added a new URL for usage checking http://10.241.0.195/
. WRONG INFORMATION. This is a private LAN address.
Check "override default domain" and try. At present 8 IP's are listed ( including new one for IP 117.xx.xx.xx)
With same set up working PERFECT for me.
Hi, I upgraded to Firefox 3 and the extension has stopped working. The problem machine has windows 2000 installed (If that matters). Finally it says "Usage Data N/A). I know the login name and password is correct as it works on one other machine with windows XP installed. The domain name is bbservice.bsnl.in Request help in debugging.Kuldeep
@/members/kkdeep000/ Welcome to broadbandforum.co.
Did you use the 14digit portal ID and password ?
Could you access BSNL - Broadband Account Management in FF.3.0 directly
Yes I have used the 14 digit portl id and password and it works fine directly in Firefox 3. The current version of DataFox is 1.4 only.
