Hello BrianI cleared the private data and downloaded the update and it is working fine now.Thanxxxxx:thumbsup::dance:
Hi .. i have Firefox 3.0.1 . I installed the datafox extn. but i cudnt log in with my bsnl userid/pwd.PS: my bsnl domain is bsnl.in. my ip starts with 117.x.x.xcan u help?thx
@essebebe thx for the info. i actually do have the portal id/pwd that i use to check acc usage on bsnl website. Only thing i didnt know that that is wat was required to put in datafox rather than my login id/pwd :) .cheers.
Oops, didn't realize that that is label is confusing if you have both a portal and a user Id, I'll try to make it clearer in the next version. Thanks for the feedback!
hey guys, m still unable to log in to datafox with portal id/pwd.also tell me wat other settings do i need to make in datafox.shud i check 'override domain'. if yes then which domain should i select?i tried many times. it just says loading... and then never logs in..
If the website BSNL portal is not available DATAFOX will not be able to extract the latest data. and simply show loading and stop. see other options in link given.
Example only. I cannot check my usage (As my IP is 59.xx.xx.xx) at this portal.
Yours: 14digit portal ID password password.
Later click preferences . How you want the data to be shown, with color background.
REFERENCE:https://broadband.forum/bsnl-broadband/22290-bsnl-broadband-billing-problems/#post184528 page 7 post no 69 mine for all meters.
As in the screenshot above, make sure you select bbservice.bsnl.in from the override drop down. This is all mentioned in detail on the site, see the link in my footer for details.
