is this extension also for mtnl users ???
Yes . but i read some problem for MTNL users with some @ in ID. not sure
.Download and try. Different menu buttons for BSNl MTNL mumbai and MTNL Delhi.
Hi Infernal,
I am not able to log into DataFox.
However I am able to log into the portal site 10.240.144.195 with the same password and username. Datafox does not work even though it is set to the same IP address.
I am using Datafox 1.5 and FF 3.0
MY BSNL Ip starts from 59.xx.xx.xx
Any help will be appreciated.
Suggest try an older version, after uninstalling 1.5.
I will also try in my
Inspiron 8000 laptop.
The Blackdot in front of month does not appear.
Presume same fault for you also.
Reported to @infernalproteus
New version modified for users with Ip 117.xx.xx.xx
MY IP 59.xx.xx.xx and Datafox works Ok in Vaio Fx215 laptop with Xp SP2 etc. FF.3.0.3
Please wait till November say 20th as the programmer is other wise pre occupied.
Sorry for the long hiatus guys, but I had some other projects which were actually years out of date and required immediate attention.
Back to DataFox now, I was looking at the BSNL Portal portal today. I was able to use the same account I used on bbservice.bsnl.in with this new portal to get records. I have the following questions:
1) Does data.bsnl.in/wps/portal work for everyone? (Excluding the times at which the site goes down, is the portal up most of the time?)
2) I assume bbservice.bsnl.in does not work for everyone, some users reported that it works sometimes, but would sometimes redirect to bbservice.bsnl.in/wps/portal Does anyone know if this still happens?
While I will most likely leave the legacy implementation in for bbservice.bsnl.in, I would like to know if data.bsnl.in/wps/portal is now the default place where all the 117.* users can get their records.
3) The data.bsnl.in portal has "Unbilled" and "Billed" drop downs. As far as I could see, records for the current month are available in "Unbilled", records for past months are available under "Billed". It does not really correspond to your billing cycle. Right?
P.S. Brian.
A user recently asked me to add some cost computation to DataFox, i.e. how much extra you will be paying if you go over limit. Of course, you need to supply the limit and the cost per MB above limit. Would you find this useful?
@infernalproteus
Hope you enjoyed your stay abroad. Happy New Year.
Failed with sp2 update and also sp3.
As reported earlier, working fine in another laptop
identical conditions Sony VAIO Fx 215.
seems available most of the time when bbservice.bsnl.in fails.
has more options, security. You have to enter acct number also.Calender incorporated. ( not checked recently)
If required , will send SS with a test userID for both sites.
( If password Not changed !!!)
Mine 59.xx.xx.xx
Observed:
When month is selected Black dot should appear
for Datafox to function. ( as In other laptop)
Will post screen shot of FX215 about:config later here. .
Para two: Majority IE users as well as FF users,
rather struggle with BSNL portal to check usage!
By adding bill amount more complications.
Please avoid. Keep this simple.
Recently Govt employees etc, given 20%
discount on additional BB usage above free quota.
Imagine the different Tariff plans to be programmed
and the amount charged varies Rs 0.80 to Rs1.00. per MB.
@infernal proteusOk on Inspiron 8000. xp pro sp3 FF 3.0.5 Black dot against month appeared.Password saved.Thanks. Any update done ?
Hi,
It was me who had requested for a price check on over quota usage. My point was just provide a field for the user to enter his multiplier amount. So, if the user is being charged .80 paise, he enters .80, else a discounted user enters whatever rate he is getting. The plugin will just need to apply this to the excess MB and show the value.
@infernalproteus
Mine 59.xx.xx.xx
Observed:
essbebe,I went through the code that manages the month menu and couldn't figure out why it isn't showing the current month selected. What exact strings do you see in the month menu? Are they in the "mmm yy" format? If you enable DataFox debug (see previous posts about turning debug on, let me know if you can't find these) and open the the Error Console, what string do you see when you select a month? It should say something like "Selecting month: ...."Brian.
From Post 324. Janauary 31st 2009.
@infernalproteus
Password saved.
Yes I compared about:config when it failed and started working.
Could not see any difference EXCEPT i had entered my user Id
wrongly. In the meantime SP3 update was done, and FF UPGD to 3.0.6.
If interested will send screen shots of FF about:config page.
Thanks. Will get feedback from others.
please repeat. difficult to scroll all posts.
essbebe,
Only suggest that after step 3 you restart Firefox and proceed.
The other values in about:config are irrelevant in this context, so don't bother spending any time with it.
Let me know how it goes. Thanks
