hello friends .. my dish tv subscription came to its end , all the programmes including the dd fta channels are stopped and only instructed me continously to contact cc but i dont want to recharge it .. now my request is ... is any body converted the dish tv stb zenega model cd-1004s... to view dd dth fta channels with min amount .. i am in chennai .. if yes pls help ..
Hi, If you load the old verson software, you can watch FTA DDD+, please contact your Local Dishtv supplier, they will do it unofficially at reasonable charge (Rs300/-).
i was also got the same problem, i did as above, i am watchinh FTA now.
No, you can't use Dish TV STB to view FTA channels. Better buy one FTA STB (around Rs. 500) to view channels from DD+
ok .. which one brand and model is best ..
for now and future use with dish tv antenna ........
you can use by changing some s/w or H/w modifications. my cousin is receving dd direct plus by making s/w changes. u should not try to access NSS satelite
