no app on jio STB currently supports 5.1 Audio I have tried contacting Amazonprime video support 100 times and in the end they concluded by telling me that JIO STB H/WDosnt support 5.1 audio (but STB Supports 5.1 audio ) and they wont provide any support regarding this. the only way u can play 5.1 audio is through Photos App provided by jio else no other way is possible what we can do is contact Jio Care until they fix this
Yes i have also jio set top box it doesn't support Dolby audio from ott apps like Netflix prime Hotstar but you can watch Dolby digital 5.1 movies from photos app and can enjoy 5.1 movies from through usb or cast method which will play through photos app the movie file should be in Dolby digital not(Dolby digital plus) this will not play the movie in Dolby digital plus format
@Bucky No, Jio STB cannot be connected to a dish antenna. It either needs a Jio fiber internet connection or there are some hybrid boxes used by Hathway and Den cable operators, which need cable TV input
Anybody found Audio settings for Jio STB where we can change Audio from maybe Surround to Stereo?
In Zee5, Sony Liv and some other apps, dialogues audio is very less, but background music is very loud. Can't really understand dialogues for most of apps.
