@chart
Welcome to broadbandforum.co.
hope the cdbsnl .zip is what you need.
Welcome to official Website of BSNL Assam Telecom Circle
CD download:
http://www.assam.bsnl.co.in/CDBSNL.zip
Huawei modem driver.
http://www.assam.bsnl.co.in/Huawei_Driver.rar
fOR evdo SEE EVDO FORUM
Binod Kumar Singh: Modem settings of WLL FWT's
WLL cdma Hantel HTP 800A
Configuration of HTP-800A-Hantel set for Internet(PDSN):
1. Without connecting the instrument to PC , Install the USB Driver - Run the setup.exe
file. TELSON Folder will be installed
2. Connect the instrument to PC using Data Cable (Instrument end – Data Connector
& PC end – USB Port).
3. Modem settings in PC –
Settings - Control Pannel – Phone & Modem options – Modems – Select Modem (TELSON
Handset)- Properties –
General – Max.Port Speed = 115200 .
Advanced - at+crm=1.
5. Setting / Programming in IFWT (instrument) –
Press MENU – 0 – 4 – 1 – Select 2.Data – Select USB CDC – Press Store
Press MENU – 0 – 4 – 2 – DS BAUD – 115200 – Press Store
6. Detecting Modem / Query Modem Procedure -
Settings - Control Pannel – Phone & Modem options – Modems – Select Modem (VIA
CBP4.0 modem) - Properties – Diagnostics – Query Modem.
7. If modem is detected successfully (Response to All parameters should be OK after Query
then create dial-up connection as follows -
For
Windows 2000 –
Settings - Control Pannel – Network & Dial-up Connections – Make New Connection –
Dial-up to the Private Network – Phone Number = > #777 ( Disable ‘Use Dialling rules’)
- For all users – Name of Dial-up Connection –
–User name and Password is given by BSNL authorities
