Exe problems
  • Thread starter Thread starter udayag
  • Replies Replies 33
  • Views Views 5,791
udayag
Hi, Friends i am not able to download any exe files can somebody help me out of this. i have complained to bsnl but no response.has anybody faced the same problem.OS is win2k.Any other file no prob.plZZZ help me.
Never had any problems in downloading EXE files.What exactly happens or what message do you get?
even with download managers not able to download any other fil types except zip,rar or rm files can somebody give a answer for this.
hi udyag,it seems that the problem is not at the BSNL side, coz i think that doesnt matters what type of file you are downloading...for bsnl its just DATA.there might be some problem at your computer. may be some firewall, some spyware or some security that would not allow you to download files...check out again..and correct me if i m wrong guys.Sandy
Originally posted by Bluegene@Sep 13 2005, 12:45 PM
hi udyag,
check out again..
Sandy
[snapback]24981[/snapback]
[/quote]
i have formatted the system now and still it is the same prb.Has anybody faced this prb.
It might help the members here to give you a more accurate response if you mention the exact antivirus or antispyware you have installed.. and any error messages that you get while trying to download the *.exe files. Also please check out your user/administrator privileges in the OS. A wild guess, try using "save to disk" option instead of "run ...." option. while downloading
I have norton antivirus installed but without that too i have tried but still not able to download i tried with netone and it is working fine.
OK tell us what procedure you use to download a file (i know its silly question, but might be of some use) also tell use what happens when you start downloading it...i mean does it stops responding (just hangs there as it is) or it gives some error.if it gives some error tell us wats the error is?Sandy
Hi,When i click on the link it just hangs on with any browsers if i use any Download acclerators then some threads might download but the file is not completely downloaded. But strangely this happens to any file other than zip,rar,rm files.I thought some virus and formated the system.i have installed norton antivirus but still the same thing is hapening.Can u help me plz.
