Should i change the OS(WIN2K with IE 6) i dont know bcoz i tried with NETONE with the same OS and the files are downloading without any prob.Then wht might be the problem if virus or spyware then it should also not allow through NETONE.Can somebody help with this situation.
I had reset my modem to default settings and gave my user name and password I can view the sites and download zip and rar files but when tried to download exe files still i am unable to download the files..My modem is MT882 the latest version.Can anybody guess what is the prob
Try this , My Computer-Tools-Folderoption-File Type -search for exe extention and delete the key. May this will solve the problem.Try to find the programs running in Task Manager - Image Name UserName and give detail of the name of no. of process + name of process running.
if other process does not work you should very very carefully try this.Go to Start-Run-Regedit-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Plugins\Extension\.exe Note down if any key exits in that folder or export it and then delete if any exists in it. carefully close it and reboot your machine.Hope this will work. MAY GOD HELP US.
Hi, The steps which were in the earlier reply could not help me.Ok can u tell me whether ADSL and Lan link should have green colour or orange bcoz i am getting both orange .Is this the problem with the line connection.When i use USB port it is green colour.But i tried with both and could not download exe files.Can somebody answer me.Thanks in advance.
