the D-Link runs dd-wrt and its highly stable btw( last reboot was around 20 days bck). the speed also depends on the distance from the router. when my laptop is in the same room as the router i get around 5-5.5mb/s. but usually they are not in the same room hence the horrible speed. in any case i hardly download thru the laptop dd-wrt usually beats everything in stability from what i have seen in my limited use.
@mgcarleyYes the Linksys WRT54G2 I have is running dd-wrt firmware. Security is set to WPA2 Personal AES. My laptop wireless card is Intel WiFi Link 5100 AGN. The download speed I get is 2.2 Mb/s in the hub. Laptop is used in the same room to download as the router.Now keeping all these things in mind will a Wireless N 150Mbps router give better speeds than my current one?
it will be better than ur current one but only about 50-60% of what u wud get with a wired line. if ur ok with tht then go ahead. but don't forget tht u wud get 5-6mb/s with Netgear/Ciscorouters. not the cheap models though.
dude from what i have read the new TP-Link is ver3.0 which has no support for dd-wrt. v2.0 had support for dd-wrt. without dd-wrt i woudn't recommend this.if u can push ur budget up by 300-400 rs then i say go for D-Link dir 615. put dd-wrt on it and its one hell of a stable router. wireless N 300mbps. also dlink honors the warranty even after u install dd-wrt. it has detachable antennas in case u want to replace them. u shud find it @ lamington for around 1800-1900. also plz check if the latest router version supports dd-wrt or not.
Really? How'd you get DD-WRT into 2MB? Have they got a lite version out now for the newer models of the WRT54G?
I will be happy if I get speed of atleast 3Mb/s.
My budget for a new router is Rs 1500. Which one would you suggest?
Neither of these routers support either DDWRT or OpenWRT... well, technically the WGR614 does if you get the right version but I'm not sure if the one you'll get from Flipkart will be the right version or not. Also, it can be obtained for less at Lamington Road.
Also, my experiences with TP-Link (albeit an outdoor AP) was less than favourable.
dude from what i have read the new tp link is ver3.0 which has no support for dd-wrt. v2.0 had support for dd-wrt. without dd-wrt i woudn't recommend this.
