i don't know what the latest revision number is. u will have to ask some shopkeeper what the rev. number of the latest model is(i have rev.e3) . then search for the relevant dd-wrt file. if a file is available get the router. i stay away from Linksys coz 1) no dd-wrt. stock linksys firmware is useless. 2) the low end models are no good in terms of range etc. the reviews are also not nice.
@mgcarley
he is going to use dd-wrt so no. of open connections can be set higher upto 4096 via gui(Ip filter settings) ( u can set it higher than that thru command line). i have it set @ 4096 and i download through the ethernet port of the router. never had any problem. i download a lot of stuff btw. approx 30-40 gb on weeknds without any reboots. if i don't have problems then i doubt any1 esle is going to have.
the only ppl who complain about D-Link are the ones running the stock firmware which is utter crap. u r completely missing the point that the stock firmware is never going to be used here.
the only reason i m recommending dlink is based on the understanding tht he is going to use dd-wrt.
i wud never touch any sub 5k linksys product with even a 50% discount.
here is a review of wrt120n
http://www.smallnetbuilder.com/wireless/wireless-reviews/30900-linksys-cisco-wrt120n-reviewed
@mgcarley
