Getting 2mb speed in a ULF1400 PLAN
  • Thread starter Thread starter KopOut
  • Replies Replies 9
  • Views Views 2,172
KopOut
Regular
Bsnl
I am supposed to get 4mb right? and where do i see if i have exceeded 25gb limit or not? Portal wasnt much of help.
Yes. You should be getting 4 Mbps till 25 GB. It is better to use a bandwidth meter to keep track of usage. Try Networx or Shaplus. You can try Shaplus Dataone tool to check the value in portal.
Tried Shaplus tool but its only gives whats in portal, which don't give any info about current month.I used to remember a firefox addon when i had Limited connection with night unlimited. it was very useful, anything like that out there?
With UL 1350 [2mbps] I am getting 1 mbps since yesterday - so seems like BSNL has reduced the bandwidth by 50% on all plans :P
I think you are talking about datafox. That too will give what is available in the portal. Talk to the Senior Divisional Engineer (SDE) and seek help.
bsnl 4mbps plans are available only in metros and they are doing fake advertisements in other cities. Even i am victim of this fake advertisement.
Still getting 2mb but haven't got lower speed after 25gb yet (which it should as i downloaded lots of stuff) If it stays this way i wouldnt compliant a one bit :smile: :D
you are lucky....
Not so. Spoke too soon now i am getting 256kbps :frown: Dumb plan. should have stick with ULF 1350. my bro mistakenly applied for this.
