getting speed of 5-10kbps
  • Thread starter Thread starter wishal
  • Replies Replies 5
  • Views Views 1,824
wishal
bsnl
hello friend having DG834G Netgear router and i am getting speed of 5-10 kbps in morning free hours of home 500c plansometime if i restart the modem i get speed of 150kbps for download bt again after finishing downloading one file i get 5-10 kbps and i need to restart the modem and sometime it work and sometime it doesnt workis there any settings????????????? problem especially in free hours more.
Welcome to broadbandforum.coPost ipconfig /all data.START run type cmd type ipconfig /allYou can enter/try OPE$NDNS 208.67.220.220 and 208.67.222.222.Start /network/LAN/propertiesTCP/IPpropertiesDNS (* enter here )apply Save. Test speed at speedtest.net say Mumbai and Dallas.
u can try using this software called TCP optimizer for ur OS
I tried it and it really boosts ur download speeds :thumb:
OR ELSE JUST TRY REPLACING UR MODEM TELLING THE BSNL LOSERS THAT ITS BUSTED OR SOMETHING
Those suckers wont even bother checking
Government workers are always like that :wall:
one more thing is tht when i get good speed for download after downloading one file when i try to download another file, speed get low like 5-10 kbps whts reason for this ???? is it modem fault or computer?
Hey Wishal
firstly tell me what sort of file are u trying to download
Sometimes when u download torrent file ur modem or router tends to be slower due to an overload of heavy usage
then u can try restarting the modem
if ur problem is the same for direct downloading and video streamings as well then there must be a problem with ur modem:huh:
But before being sure u can clarify whether there is a problem with ur firewall
Try using COMODO firewall
Its free and easy to use
U can get one from this site
Free Firewall Protection Software Best Firewall Computer Security Free Personal Firewall:thumb:
Have u tried the TCP Optimizer software
if not try it u can get it from this link
http://www.speedguide.net/downloads.php
And if there is still any problem then reply to me
Well one of my friends is also having the same problem and I m consulting my software engineer friends to help him
I'll return to u as soon as i find a solution to this problem:D
Ya and sorry for being late in replying to this message
actually I was busy with my exams
thanxxxxx:cool2:
@viikraam
Suggestion 1:
Try opendns 208.67.220.220 and 208.67.222.222
Suggestion 2 : Download user manual.
http://tinyurl.com/agqwcz
[Open in new window]
Query1:
Which is the Download Manager you use ?
Query 2:
When problem is seen, recheck
speed at speedtest.net say Sydney server.
Query 3:
Did TCP/IP optimizer application help ?
