BSNL has launched couple of new plans during past few weeks. However those plans are not yet updated on BSNL Selfcare Portal. Many people are confused about the plan change procedure and asking questions in different threads. While we have answered the questions in each threads, it has become scattered and is hard to find. So creating a separate thread for plan change.
What is the issue ?: Latest BSNL plans are not available in BSNL Selfcare portal. Customers are being made to visit BSNL exchanges to submit written plan change request.
The solution:
1. Manual Override in the BSNL Selfcare portal
2. Social media complaint
1. Manual Override:
This method works 100% in Karnataka. 4-5 friends,neighbors of mine got plan changed this way within a day without visiting BSNL Exchange. Hope this helps. If any further assistance is needed in plan change please reply to this thread. I will be glad to help.
The solution:
1. Manual Override:
- Vist BSNL Selfcare Portal. Users from Karnataka/South India can access it at http://selfcare.sdc.bsnl.co.in/ . IIRC the link varies from region to region. Please do a search for exact link. Login to the portal.
- Click on the Service tab. You should get Submit a New Service Request option at 3rd position. Click on that and select "Service ID" from drop down. Then select "Request type" - Change of Broadband Plan.
- In the New Broadband Plan option just manually type in the plan name such as BBG Combo ULD 1199/ BBG Combo ULD 499. Fill the summary and description option. Give plan link from BSNL website for their reference.
- Submit the request.
- You will get a Docket number at Check Status Of A Service Request option in previous page. Copy this number.
- Visit Twitter and tweet to BSNL India (@BSNLCorporate) | Twitter and to your state BSNL handle ( For Karnataka its BSNL_Karnataka (@BSNL_KTK) | Twitter). Mention docket number and phone number with STD code clearly.
- They will change the plan and reply on Twitter. Same should work in Facebook.
- This is usually done within few hours.
- Visit BSNL page in Facebook or Tweet to @BSNLCorporate & your state BSNL handle along with your landline number with STD code. Request them to change the plan.
- You will get multiple calls from BSNL City/District/State Headquarters confirming plan change request.
- This process is slower than Selfcare option. Takes 1-2 days.
