[Guide] How to host webservers on Jio Fiber, accessible to IPv4 clients
  • Thread starter Thread starter poiasd
  • Featured
  • Replies Replies 89
  • Views Views 44,578
As you might know, Jio does not offer static IPv4, and it is not easy to apply for port forwarding (for Camera etc. purposes). However, they do provide IPv6 and this can be used for hosting web servers.
To allow IPv6 incoming connections to your device (e.g. a PC running nginx), you need to disable all firewall rules in Jio Router. (At least initially for ease of setup / troubleshooting - once you get it working you can slowly tighten it up).
Your device on which you want to host must be connected to your Jio router directly (Wifi or LAN) and must have IPv6 assigned from the Jio router's DHCP.
On your device running webserver (nginx, plex, whatever), make sure it is bound to localhost or the IPv6 equivalent (NOT 127.0.0.1 - this wont allow IPv6 connectivity). Usually apps bind to all network interfaces so you should be fine.
From command prompt (or equivalent), Type ipconfig all (if you're on linux you probably know the commands - but it should be ifconfig), and view your IPv6 address. This is indeed your "Public IPv6". Let us assume it is 2001:0db8:85a3:0000:0000:8a2e:0370:7334
If your server is running on port 80, for example, you can now, from another client, access it by specifying a URL [2001:0db8:85a3:0000:0000:8a2e:0370:7334]:80. But this is limited to IPv6 clients only.
For IPv4, you need a domain name. Freenom offers free '.tk', but I'd recommend spend $1 and get a .xyz or something from namecheap. With a domain name, you can setup a cloudflare website, and have the DNS AAAA record point to your IPv6 (no A record).
E.g. AAAA record for 'randomdomain.xyz' -> 2001:0db8:85a3:0000:0000:8a2e:0370:7334
Set cloudflare proxy for the domain to "On". Now cloudflare will act as an automatic gateway, and IPv4 only clients can go to randomdomain.xyz, and access cloudflare over IPv4, which itself will connect to you over IPv6.
Using this method I was able to run a webserver, and had a friend in U.S. download from me at ~90Mbps (My Jio Speed is 100Mbps). This was probably helped by routing over Cloudflares network.
One caveat is - you cannot run services like FTP, SSH etc over Cloudflare, only web servers (on port 80 and 443 only, too). But for hosting Plex or something it works great.
Have fun!
There are billion to trillion IPs that are left to be allocated by the ISPs,
IPv6 is not CG-NAT’d and can be accessed by disabling your firewall and adding the rule to forward your individual port. Then pretty much the steps are very simple.
If Jio assigned IPv6 under CG-NAT then I would let me warm up my house window pints and see their locked ONT getting wings to fly straight to the road outside my premises.
Jio doesn't use CG-NAT for IPv6 (thank god!), atleast not in Ahmedabad. One thing that most ppl may not look on is setting custom "IPv6 firewall rules". Setting the "Default Firewall" policy to "Always Allow" is not enough. You gotta do this (attachment).
In the "Source IP address", you should type in the IPv6 address of only your server, this is to make sure that if any cyber attack happens, the other devices on the network aren't affected. I chose "ANY" cuz I have multiple servers on the network and not many other devices that I care about.
Have a great day !
Note: You SHOULDN'T choose "Source IP Address" as "ANY" just because I did it in my screenshot. Whatever you do with firewall is at your own risk and I'm not responsible if anything happens.
@kanishk_modi I did the exact same thing as you still I couldn't get my device to respond to pings through my Jio4g connection.
Can you send me a pic of your port forwarding setting it is ok if you blur the IP and ports but I need to understand it? How do you even port forward an ipv6 IP anyway, the destination IP can be in ipv4 only in the Jio router at least and does anyone know how to port forward in D-Link router Dir-841. I heard that if you connect another router that is not from your ISP and port forward from it though you will need to enable bridge mode.
Installed a test XAMPP on my machine. And, set to the settings mentioned above. Online IPV6 scanners show the particular ports open.
Can access the XAMPP test page on my machine, if I access it using my machine IPV6 number, over a Vodafone connection.
Doesn't work if I try to access it over a BSNL and AT&T connection.
@WandereR
1. Ensure your jio4g ipv6 is reachable by doing this test
If all green then this part is good.
2. Do the same test on your device
3. If both test green only then you should be able to ping and connect
