Reqd : Your modem model. For games \"FAST\" instead of \"Interleaved\" recommended.
suggestion 1 : Try OpenDNS 208.67.220.220 and 208.67.222.222
Suggestion 2 : tracert the gaming website :to check the path with existing
DNS
and Open DNS and see where is the delay.
11:25 PM 5/16/2008
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\xxxxx>ping www.broadbandforum.co
Pinging www.broadbandforum.co [210.193.49.171] with 32 bytes of data:
Reply from 210.193.49.171: bytes=32 time=48ms TTL=54
Reply from 210.193.49.171: bytes=32 time=43ms TTL=54
Reply from 210.193.49.171: bytes=32 time=44ms TTL=54
Reply from 210.193.49.171: bytes=32 time=45ms TTL=54
Ping statistics for 210.193.49.171:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 43ms, Maximum = 48ms, Average = 45ms
C:\Documents and Settings\xxx>
IP Address Country Region City Latitude/
Longitude ZIP Code Time Zone
210.193.49.171 MALAYSIA SELANGOR AMPANG 3.15
101.767 - +08:00
Net Speed ISP Domain
COMP GALACNET QALA.COM.SG
am using bridge mode on bsnl.. yet have tried to configure opendns..
tracert shows
Tracing route to 202-63-160-186.static.exatt.net [202.63.160.186]
over a maximum of 30 hops:
1 39 ms 42 ms 40 ms 117.198.176.1
2 43 ms 40 ms 41 ms 218.248.169.198
3 148 ms 147 ms 141 ms 218.248.255.14
4 81 ms 80 ms 81 ms 202.54.185.230
5 103 ms 102 ms 102 ms 59.163.16.1.static.vsnl.net.in [59.163.16.1]
6 103 ms 102 ms 102 ms 59.163.16.1.static.vsnl.net.in [59.163.16.1]
7 110 ms 115 ms 111 ms 172.31.153.70
8 110 ms 109 ms 109 ms 172.31.153.70
9 116 ms 114 ms 114 ms 121.240.16.94.static-lvsb.vsnl.net.in [121.240.1
6.94]
10 112 ms 110 ms 108 ms 202-63-189-10.static.exatt.net [202.63.189.10]
11 105 ms 105 ms 105 ms 202-63-160-186.static.exatt.net [202.63.160.186]
Wats the use of fast internet when it gives shYt ping on india servers itself
pls do help me configuring in pppoe alwayson mode in
router .. router is zxdsl 531b
