Hello, I have a JIDU6401
I have tried booting openwrt in ram, compiled from GitHub - AKoo7/openwrt: This repository is a mirror of https://git.openwrt.org/openwrt/openwrt.git It is for reference only and is not active for check-ins. We will continue to accept Pull Requests here. They will be merged via staging trees then into openwrt.git.
After successfully booting openwrt i have tested a few things and then tried to install as documented in GitHub - adeveloperkk/Jio-Idu6401
i ran the command
then I asked Claude about the error by showing the logs, It said to try "ubidetach -m 6", I ran that and it successfully detached, then thought to get back to stock for then, and rebooted using "reboot" command
But now when i am trying to log in to the U-Boot console, it shows following error
and does not accepts the old username and password retrieved by (/usr/bin/mfg_data get bootpass)
Also in the ssh console of stock firmware it now shows
What can I do now? Please help
i ran the command
Code:
root@OpenWrt:~# ubidetach -m 5
ubidetach: error!: cannot detach mtd5
error 19 (No such device)
Code:
'spi-nand0' is now active device
Reading from 0xeb80000 to 0xeb801ff, size 0x200 ...
Succeeded
Check magic err.
Succeeded
Check magic err.
Failed to get Username or Password! Use default ID.
Username:
Code:
Check magic err.
mfg_data_check err.
