help me out
  • Thread starter Thread starter nsaxena
  • Replies Replies 33
  • Views Views 9,584
@nsaxena Save your current modem settings ( MT882) "always on" PPP/PPPoE mode.
Try again "Dialup" "Bridged" mode . Save reboot . wait for 2 or 3 minutes.
After you dial and get the error message open modem page check "Diagnostics" . does it say Authentication failure ?
Update . Just check this.
Network/Lan/properties/TCP/IP properties/ Advanced .
WINS netbios settings : default is selected ?
OR post your TCP/IP settings. IPconfig/all
1.no authentication failure in diagnostic page.
2.wins netbios default is selected.
3.this is my all ipconfig
Windows IP Configuration
Host Name . . . . . . . . . . . . : sbi-cf1f72da363
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth
ernet NIC
Physical Address. . . . . . . . . : 00-16-76-C7-01-A8
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Saturday, January 26, 2008 8:21:40 P
M
Lease Expires . . . . . . . . . . : Sunday, January 27, 2008 8:21:40 PM
oh god,i can not understand where is problem in windows or bsnl,i think its bsnl because connection worked fine,i never change any setting in
Network/Lan/properties/TCP/IP properties/ Advanced,i always just dial and within second i connected,no problem at all,but now always 678 error,remote computer did not respond,is this dialer software works with vista also,i will install vista if i will have to go formatting and new installing of windows
"Don't throw the baby with the Bath water"
All same here. working on "Always on." presume your report is also "Always On"
DNS Servers . . . . . . . . . . . : 208.67.222.222 *additional
208.67.220.220 * additional.
Lease Obtained. . . . . . . . . . : Saturday, January 26, 2008 9:28:22 P
M
Lease Expires . . . . . . . . . . : Sunday, January 27, 2008 9:28:22 PM
In diagnostics in 'Bridged" all pass except ATM ?
In the modem enter DNS, also in computer TCP/IP properties.
Update:1030 Changed my modem beetl220Bx to MT 882.
changed to dialup mode.
see settings in wan page for dialup mode. also MINiport (PPPOE)
first attempt password was entered wrongly.
No other changes were made.
after opening remove .th for blowup.
http://img175.imageshack.us/my.php?image=screenshotnewnv6.jpg
http://img220.imageshack.us/my.php?image=screenshotnewoa2.jpg
whenever i dialed in event viewer these error occursYour computer has automatically configured the IP address for the Network Card with network address 001676C701A8. The IP address being used is 169.254.132.67.The following error occurred: The semaphore timeout period has expired. . Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.Data::wall:,what are these errors,i changed dns in both as u give me no.,but can't use dial up mode till todayi did not try yet reset factory default setting,may i try this restore,i forward port for utorrent ,i will forward it again if i reset to factory setting of modem?
Free Product Demo | IP2Location? 169.254.132.67. invalid IP address.
Since you say "Always on Mode" is perfectly working,
the fault is in settings only.
1.Did you check diagnostics page when you used dialup mode ? there are ONLY 5 entries.
Answers : All Ok ATM fail etc
2.Is the WAN page settings correct ? for dial up?.
Repeat here your settings.
3.Did you check Wan mini port properties ? There is no DHP involved.
4.
Since you say \"Always on Mode\" is perfectly working,
4.
this ip address location is in america:confused:,how it can be possible:(,ok now i am checking all things u said i will report u in morning,sorry for annoying you too much:redface:
Just added another random IP number . originally it said invalid ip address.
169.254.132.67 UNITED STATES NEW YORK NEW YORK 40.7488
-73.9846 10001 -05:00 Net Speed ISP Domain - PRIVATE IP ADDRESS LAN -
IP Address Country Region City Latitude/
Longitude ZIP Code Time Zone 169.254.132.78 UNITED STATES NEW YORK NEW YORK 40.7488
Just a long shot.
If you are using IE browser go to Tools/Internet options/ connections/ Lan settings/
No check marks. auto settings./ manual settings.
vpi/vci= 1/35
FOR BSNL IT IS 0/35 sorry my wan settings screen shot shows 1/32 for Airtel.
I had to open IE just to check up . Back to FireFox.
4.
1.in diagnostic page all ok except atm fail,in dial up mode
2.wan settings are all correct,i did not change a single letter,even i did not open modem settings since u helped me.
in my settings pvc=o(pvc=6 is not working when i reboot modem with pvc=6,there is no cahnge in always on mode,i used always pvc=o in dial up mode)
and vpi/vci= 1/35
encap=llc
there are none other settings,
3.i created new connection as shown in troubleshooting,but this wan connection is not working also.
where is option of dhp in wan setting?i did not find anywhere DHP word in properties and advance tab also.
one thing is sure always on connection works without any problem yet,
i tried all options but same error when i connect 678 and in event viewer error is
Your computer was not able to renew its address from the network (from the DHCP Server) for the Network Card with network address 001676C701A8. The following error occurred:
The operation was canceled by the user. . Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
but when i changed back to always on,no problem at all,
i want to ask one thing also,is this our right that we can use dial up mode or always on as our wish,or bsnl officially allow only always on,because bsnl person who came in my house several months ago told me that don't open settings with admin password of modem and don't change anything in modem setting in always on mode,if problem remains same i will call bsnl person to work connection in dial up mode,i will say to bsnl ur connection is not working but certainly he will change modem setting in to always on,then is this our right to take connection in dial up mode as we wish our any rules there in bsnl who advocate only user can use any connection always on or dial up anyone which is working?
vpi/vci= 1/35
I had to open IE just to check up . Back to Firefox.]
i wrote wrong,yea it was 0/35
no check marks its already set as in screenshot
