help me out
  • Thread starter Thread starter nsaxena
  • Replies Replies 33
  • Views Views 9,584
confirm this.
Just a long shot.
If you are using IE browser go to Tools/Internet options/ connections/ Lan settings/
http://i26.tinypic.com/34ioiee.jpg
No check marks. auto settings./
i did this,but as i said i did not do to check marks remove as there was no check marks already,confirmed
If you can, try firmware update at your own risk !
Downloaded by IE only.
What is the present firmware version ?
http://www.link-removed.com/file/dlfifz
Description: V100R002B023 firmware for Huawei MT880 and MT882
The download link is located below
Send big files the easy way. Files too large for email attachments? No problem!
this is my current version
Current Firmware Version: V200R001C01B021SP03 Firmware Date: Jun 20 2005
what is negative effect will happen if something goes wrong?this upgrade will solve this problem?what change will it make in modem,any new option will be add or deleted by this, please answer these questions to clear my doubt
Wait. I will ask cool_tech_tvm who has done this firmware.We will compare the modem with new firmware to pinpoint the fault.I have d/l the firmware but not doing it, as my modem is working ok.same firmware what you have quoted..Para two : 1.Let us assume that your dialer program in XP is corrupt.I will give the details like version etc later.If you want you can download the broadband dialer from tataindicom and try.2. Disable Windows firewall/ and any other firewall like Norton/Macfee and try.Keep antivirus program only. Exit max programs appearing in taskbar. 3. Still getting the dud LAN IP address ?
2.i never use firewall of any type,i disabled windows firewall since i installed my windows xp,i have only avg antivirus which does not check lan connection,tataindicom dialer will work with this modem also,ok i will try from where i download tataindicom dialer,i deleted corrupt dialer and installed new one but same problem with this also,i install windows in microsoft virtual machine,and install this dialer but in virtual machine always on works and not dial up mode
i downloaded but only help is installed and not dialer in dos window show that access is denied
I tried. AVG virus report received in exe. file. . Seems meant for Dialup service.
edited 1945 I did search WAN miniport repair in google.
Now read this and try.
Winsock repair may help. LAST RESORT
You may receive Error 678 or Error 769 when you try to connect to the Internet or when you try to browse the Internet after you install Windows XP Service Pack 2
As previously mentioned,causes 5 & 6 are the most likely.
- Winsock messed up by spyware
Firewall messed up Winsock :)
Solutions :
Repair the Winsock.
See that Microsoft page (Step 6)
and/or download Winsockfix
WinSock XP Fix download and review - fix XP internet connectivity from SnapFiles)
WinSock XP Fix offers a last resort if your Internet connectivity has been corrupted due to invalid or removed registry entries. It can often cure the problem of lost connections after the removal of Adw etc
i think it will work because this winsock corrupt may be reason,now i am trying all steps
