Help me !
  • Thread starter Thread starter firenze
  • Replies Replies 20
  • Views Views 3,068
thanx for the help :) dont mind but i still have two questions 1. about the security of the wifi connection which i asked in the last post which i think u forgot bcoz of the lengthy post :P 2. how to connect my laptop with my desktop via the router ???
still no replies :(
anyways
my router ip = 192.168.1.1 [PPPoE mode enabled]
my deskpop ip = 192.168.1.2
my laptop ip = 192.168.1.3
i can access internet on both my PCs SIMULTANEOUSLY now, but still am not able to share files wirelessly between them [ie with the desktop connected to modem via ethernet cable and laptop anywhere in home connected to modem via wifi]
on opening "network" in laptop [which has vista home premium os] i see only mt laptop and the modem, but no desktop
on opening "my network places" in desktop [runnin on windows xp sp2] i see nothing
on clicking on "view workgroup computers" in the menu on left side, i can see the desktop as well as the latop, but on double clicking on laptop icon it gives an error, as shown below
http://img149.imageshack.us/img149/3240/errorsoz2.jpg
i tried enabling "public folder sharing" on the laptop, but still the same error persists
then i tried pinging
when i ping my desktop from my laptop, that is successful
but i cannot ping my laptop from my desktop
how to share files koi btao yaar ????????????
OK. Have you seen the link given by me in Post 13 ?
As I have only one computer unable to test locally.Try this also . ( XP PRO SP2)
Start/All Programs/Accessories/Communications/ Remote Desktop connection.
@ essbebe : ya, i did read that link u gave.....it is a good intro for routers, but did not say anything about the problem i am having :( i tried the remote desktop as well, not connecting , tried from either side :( i had read somewhere about bridging connections....can something be done by bridging my laptop's lan card and wifi card ??? [it may sound very stupid, i have no idea what bridging does, just asking out of curiosity] :whistle:
I had read all the 7 pages dude [except the one dealing with ports, didnt read that one in detail]
frankly speaking, i didnt look this thread by seeing no. of replies . Thought it would have been solved by now !
Are you able to access both the pc's now ?
Are you worried only about Wifi ?
I will tell you how to enable wireless (Secure) ! I had replied many times ! I will paste the same here too !
login to http://192.168.1.1 and enter username/password . Normally it is admin/admin
Click on wireless -> Basic Wireless
Enable wireless [Check that box]
in SSID, give some name (you can change that utstarcom)
then click on save/apply
Now click on Security tab
For a beginner, you can click network authentication as open, WEP encryption key enabled, and choose 128 bit,
choose 1
then type any 13 Hexa digits (0-9, A-F) in 1st row !
eg :ABCDEFFEDCBA4 (total 13) Letter CASE matters !
then save n apply
now open network connection, check for wireless network, see the name you have mentioned, double click it, give the 13 digit key when it asks for encryption key !
You should be able to browse with security enabled ! Dont ever keep your wireless open to public !
incase of doubts, please reply...
(if you have norton internet security, then you may have to add 192.168.1.x range to access the other pc)
Dont worry about Bridge mode.
If you still havent able to transfer files between pc's,
Provide the details for this
Start=>Run=>cmd
Ping 192.168.1.x (x=>ip address of wireless PC/laptop)
Are you getting reply ?
Do the same from wireless pc to desktop
Ping 192.168.1.y (y=>ip address of desktop PC/wired pc)
Are you getting reply? or request timed out ?
If it is getting reply, it is easy.....
If you getting request timed out, just tell the Security/firewall you use like Norton IS, zone alarm, etc...
If you are getting reply from Ping command, then
Since you know how to share between PCs (wired), you know how to share files
Make a share folder in laptop, say d drive, named 'files'
Share it,
Check the ip address of the pc. for eg: let that be 192.168.1.2
Go to Desktop pc
Go to Start=>Run
Type
\\192.168.1.2\files
Hope you should be able to see it !!
Give update ! surely will help !
