JioFiber ONT Replacement Help
  • Thread starter Thread starter ronnie_lee
  • Replies Replies 10
  • Views Views 178
India
Jio
Hello guys, I have taken a Jio Fiber 300 Mbps plan which came with their own JCOW407 Router which is so bad with Wifi 5 tech. I have decided to replace the Router with a TP-Link one. For that I need to get a new ONT. After searching through different forums and google, I have decided to buy a TP-Link one since it fits my budget. But I do have some questions regarding the same.
1. Has anyone tried either one, and does it even work with JioFiber?
2. Should I buy the XZ000 -G3 or XZ000- G7? (More helpful if you could mention where to buy it from too!)
3 .If it does, how is the whole setup process?
Someone please guide me. Thanks!
Fed up with the Jio router, mainly because of the lack of granular functionality and speed fluctuations (based in South Kerala). I'd like the flexibility of having any router or upgrading later so I guess the VSOL + Router would make sense. What routers are recommended, apart from the XX530v @trk1k0N4 mentioned above. I had an Asus with Tomato firmware all those years ago and when I was back in the ME for a couple of years it didn't really come to good use. Thanks! Is this the best tutorial available right now?: How to Authenticate a TP-Link ONT While Bypassing the JioFiber Router?
@tr1k0N4
Hey, I have a TP-Link GPON ONU paired with a TP-Link Archer AX72 router, as I’ve replaced my JioFiber router. Everything is configured properly, and the connection works fine initially. However, after restarting the AX72, the internet stops working after around 30 minutes. The connection only recovers when I manually release and renew the WAN IP address. Have you experienced this issue or found a fix for it?
Experienced this but like I said, couldn't resolve this issue with the stock firmware. Some friends in the networking community have found a solution for it if you have an OpenWrt router.
