Help needed : connecting bsnl connection to multple pcs
  • Thread starter Thread starter in_ms
  • Replies Replies 1
  • Views Views 1,377
in_ms
BSNL
Hi everyone . As iam glad to join this forum . i need some help. Iam having D-Link Adsl2 + Router with bsnl connection i need help in configuring it to 2 or more pcs. the bsnl guys came and connected to one pc . as i tried to connect using a switch iam able to connect to only 1 pc inspite of specifing the ip address to each pc.after researching i found ot that there is a setting ppoe which has to be enabled rather than bridge connection. can anyone help me in detail how to configure for 2 pcs.and plz clear my dobuts below which i have apart from configuring. 1. the bsnl has given me user name and password if i connect to 2 pcs how to use this user name and password in betwwen this 2 pcs.2. how to remove user name and password and keep always on option in D-Link Adsl2 +router3. If i keep alwys on option does my bytes tranfer used. if i dont use my net connection Thanking You in advance for any sort of help provided. ms
Welcome to Broadbandforum.in
You get connected to Internet with BSNL ID and password.
Thereafter you can connect any number of computers.
Intimate the Modem( supplied by BSNL) and/or D-Link model No.
see the following web sites.
BROADBAND MAIN MENU
Download
