help
1.will the movie play continuously in video streaming or it will have to buffer for scene to scene? 2.i also have another problem when i download both from torrents and normally i am getting speed of 120kBps and i can also download from other sites but i am getting less speed around 15kBps but when i stop the downloing of torrents i am getting more speed in flashget it is around 22kBps why it is happening like that can i download both from normal sites and torrents at 120kBps speed each that means both at a time
i also have another problem when i download both from torrents and flashget at a time i am getting speed of 120kBps and 15kBps but when i stop the downloing of torrents i am getting more speed in flashget it is around 220kBps why it is happening like that can i download both from normal sites and torrents at 120kBps speed each that means both at a time when i download from torrents i am getting a speed of 120kBps if i download 10 torrents if i download 1 torrent my speed is around 30kBps why is that happening the torrent is healthy it have 163peers and 10 leechers
what is this dear !
write down all your problem.. which one to reply ?
Generally.. You cant expect 120KBps speed on 750UL !
If you have started to download something else, your Movie buffering will be very bad !
You can watch movie at a decent speed if the quality is average ! (if there is no parallel download)
If the movie quality is excellent, your buffering will take more time !
Do one thing. If you are worried about movie watching, Just get up around 2.. Restart the router, put for download (not for buffering.. but thru torrent or others), and around 8 AM, stop all the downloads.. restart the router!
I dont think UL750 is a good choice for you .
You are talking about 230kBps, 130kBps and stuffs..
You can only think of 32kBps in ul750 ! It can be even lower and sometimes higher too..
But you cant dream anywhere near 120kBps in 750Plan
So stick with 500C but download only at Night (after restarting router before 2 and before 8)
sorry i said i am getting a speed of 120kBps in home 500 i also have another problem when i download both from torrents and flashget at a time i am getting speed of 120kBps and 15kBps but when i stop the downloing of torrents i am getting more speed in flashget it is around 220kBps why it is happening like that can i download both from normal sites and torrents at 120kBps speed each that means both at a timewhen i download from torrents i am getting a speed of 120kBps if i download 10 torrents if i download 1 torrent my speed is around 30kBps why is that happening the torrent is healthy it have 163peers and 10 leechers this is in home 500
Use '.' and ',' in your sentences. Wont hurt you :)
Anyways
Did you have port forwarded your modem/router ? If not read the portforwarding section in this forum ! Torrent to work to the highest speed, you need to port forward (ie, opening a particular port in your PC to public)
If you have a total speed of 240kBps, and the site having speeds, it is quiet possible
Port forwading !!! Seeders should upload too (if they set upload speed less, these problems may occur)
Thankssssssss !!
thanks one and all for helping me i have decided to go with ul750 plan i will see how it works with me if it not good i will again switch to home 500 king of kings btech 3rdyear everyone things to change the world but no one things to change himeself "including me"
Very true :P
(No place for Things, let us Think!!!!)
Remember, you may have to wait 3 months to shift from one plan to another. Please confirm with authorities !
Very true :P
appus suppose if I take Home 500 now and after one month I decide to shift to UL 750, then do I really have to wait 3 months to change to it ?:(
Ok I will ask the Bsnl guys. But really they should allow to change it after 1 month since change to UL750 Plan will fetch them more revenue. :P
