Help....
  • Thread starter Thread starter pradeepans
  • Replies Replies 5
  • Views Views 1,211
pradeepans
BSNL
Hi, I am curently using home 500 plan, the speed is gud, now i thought of upgrading to Home 750UL plan, but i use to voice chat in my 500 plan, which is quiet speed & response wen v talk, due to 2mbps, but how abt 256kbps home 750 plan? will b the voice chat will b same as home 500 r...? any suggestions?plz help :huh:
You will not have problems with voice chat at 256kbps, it will be almost as same as 2mbps, if there are not many people. But Video-chatting will be undesirable.
@pradeeppans
Welcome to Broadbandforum.in
It is downgrading speed!
Home 750 unlimited at speed upto 256 Kbps gives
you unlimited download 24/7.
Home 500 day limit 2.5GB NU 0200- 0800 free.
speed upto 2 Mbps.
Assume you d/l 24 hours on Home 750 32KB/sec( *max)
( *conditions apply)
Same in NU 0500-0800 ( 3 hours) in Home 500 (256KB(*max) ( *conditions apply)
The ratio is 1 :8 the time you spend for same work
Stick to Home 500.
If you want to have voice chat with persons/relatives in U.S
time difference of 7 to 10 1/2 hours also counts.
EARLY MORNING 6AM HERE NIGHT in U.S say Range
8PM to 11PM
(Eastern time/ Central time Pacific time etc)
well if you talk a lot then its better to have a UL plan.. so you dont have to worry about the limit.. nor do you have to restrict your talking between 2-8am..
One sugestion.. When you create any thread asking for help.. Plz specify what kind of help do you need, a little description would do.. Many people will not reply to ur post if you just post it as help!!..
