It used to show data in app or website but now it just says "Data Balance Unlimited"(quite an anime reference). I don't use jio set top if its only visible there.
It is visible in the Jio STB but since you don't use that what you can do is you can generate a monthly statement from Jio app where you can see the data consumed (detailed).
Or else just to know the data left you can call like @lucifer said.
