MY CONFIGURATION IS SOMETHING LIKE THIS:
WA3002G4
ADSL MODEM CUM
ROUTER (WIFI)------ETHERNET----DESKTOP
* OK. also ~~~~~~~ wireless signals limited range )
WIFI ACCESS (WANT TO ADD SOMETHING WIRELESS HERE TO EXTENDE RANGE/ SIGNAL) (* Not needed. see below )
LAPTOP (BUT SIGNALS ARE WEAK HERE SHOWS ONLY ONE BAR & DISCONNECT
(* adding another Wireless AP unit for different floors )
QUESTION
How can the WAP54G be set up as a wireless signal repeater with the WRT54G router?
https://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=231
h t t p s://
Linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=231
2.
I think with WA3002-g4( similar to WRT54G)
you can combine the linksys WAP54G.
You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G.
Para two:
Security etc clearly explained in above site.
Feedback.
