How to renew IP in a PPP connection?
  • Thread starter Thread starter akl007
  • Replies Replies 3
  • Views Views 4,783
akl007
BSNL
I'm using H500 C+ plan of BSNL. I connect to net via WiFi and my modem is configured in PPP mode. In order to avoid mixed usage from 2 to 8 what I used to do is turn off the modem and turn it on during 2AM. Is there any other way to renew the IP without turning off the modem? Does turining off and on the Wifi in my Laptop renew IP? I cannot use a bridge connection coz lot of people are connecting at the same time thro this connection.
Hello Aki007,In run type cmd>enterin the black window type ipconfig/all > enterThis will display ip address of your network devices.Next type ipconfig/release > enter this will change all ip addresses to 0.0.0.0Next type ipconfig/renew > enter. This will renew your ip addresses.I hope this helps.KaranbirSoin
when I type ipconfig/release its showing: The requested operation requires evaluation.when I type ipconfig/renew its showing: No operation can be performed on Bluetooth Network Connection while it has its media unplugged
In status of your connection click the properties tab and check for tcp/ip properties.
The automatic ip address and automatic DNS address options must be selected for the renewal of ip address.
---------- Post added at 06:05 PM ---------- Previous post was at 06:01 PM ----------
Is your question that how to switch off BSNL network without switching the modem.? If so then yes open your network connections and right click on the active connection and select disable. This way there will be no connection between the modem and your computer. when u want to start just right click the connection and enable it . this will restart the browsing after the ip address is renewed.
---------- Post added at 06:05 PM ---------- Previous post was at 06:05 PM ----------
