How to Unlock JioFiber ONT & work directly with any ftth ISP without using another ONT or Use it as a WiFi Router by connect any FTTH ISP basic Modem?
SG_curiosity
I got banned!
Jio, BSNL
Is JioFiber ONT is locked for any other ftth service providers?
Any one had tried to hack/unlock the JioFiber ONT for other ftth service providers like bsnl ftth? Is there any way to use Jio ONT for bsnl ftth?
Jio has disappointed me and i don't want use it for few months till it comes with better plans and with 1:1 download/upload speed.
I am think to try bsnl FTTH because it is now available in my location but currently I don't want to buy or rent another ONT for it.
So, Anybody have any knowledge to unlock Jio ont or have anybody just tried to connect Jio ont with other fiber isp like bsnl ftth or local isp etc?
Or
If unlocking is not possible than atleast how can we use JioFiber ONT as a dual band WiFi router by connecting it with basic Modem of other ftth ISPs like bsnl FTTH (by using bridge mode or by any other techniques) ?
Anybody have tried ?
lol i do not even root my phone. depends upon how popular jio becomes, i assume eventually it would become part of the open source community with custom roms for their android based set top box. xda might even get a dedicated section and so on. might be too early for that right now.
Upvote 2
ISP provided CPEs have custom firmware and will in all likelihood not work with other ISPs. For e.g. though Tata Sky BB uses Nokia I am not sure if the same Nokia will work with Airtel. They load custom firmware before installation and it is not possible to get firmware update files from anybody (even the mfr!) except the ISP.
It is better you buy a new ONT in the market after making sure it is compatible with Jio Fiber.
Considering FTTH is heavily locked down platform where ONTs are validated by manufacturer and it’s serial number, there is faint chance you can use Jio’s ONT for anything else.
@C3PO can't we even use it as a WiFi Router By connecting it with basic ONT Modem of other ftth ISPs like bsnl FTTH (by using bridge mode or by any other techniques)?
Even if you get a compatible ONT, most ISPs have their ONT serial numbers/MAC registered at the OLT, so it is not as straightforward as simply plugging in a new one. The new ONT has to be activated at the OLT or it won't work with the GPON LED flashing or turning red. And then there are different ONTs for GPON and EPON networks which are not compatible with each other.
Please consult with Jio support to check if and how you can change the ONT to bridge mode and then use a router of your own to perform authentication and Wi-Fi. I had to get my Tata Sky BB Nokia WiFi ONT changed to a dumb Nokia ONT (no WiFi) because the wireless model does not support bridge mode. This whole set up varies from ISP to ISP. Save your time and $$ and contact Jio for guidance. Otherwise you will be running around in circles.
