Huge Ping Difference
lucky_chouhan
Regulars
Airtel 256 (353) Kbps Unltd.
Hi guys when in run the ping i see huge ms differece between the servers.
C:\Documents and Settings\lucky_chouhan>ping 59.144.152.1 (airtel Server)
Pinging 59.144.152.1 with 32 bytes of data:
Reply from 59.144.152.1: bytes=32 time=43ms TTL=127
Reply from 59.144.152.1: bytes=32 time=61ms TTL=127
Reply from 59.144.152.1: bytes=32 time=93ms TTL=127
Ping statistics for 59.144.152.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 43ms, Maximum = 93ms, Average = 64ms
C:\Documents and Settings\lucky_chouhan>ping www.yahoo.com
Pinging www.yahoo-ht2.akadns.net [209.131.36.158] with 32 bytes of data:
Reply from 209.131.36.158: bytes=32 time=308ms TTL=54
Reply from 209.131.36.158: bytes=32 time=327ms TTL=54
Reply from 209.131.36.158: bytes=32 time=358ms TTL=54
Reply from 209.131.36.158: bytes=32 time=326ms TTL=54
Ping statistics for 209.131.36.158:
Minimum = 308ms, Maximum = 358ms, Average = 329ms
that's becoz airtel servers are probably located in india maybe closer to where you are accessing the internet.
