I have changed my plan from Home 500 to Home UL 750. I m getting low speed of 200 to 400 Kbps. What to do ? It sucks.
Hey the speed you have mentioned is way more, officially your speed should be around 225-256 max, but due to cable problem which happened all over india you are getting that speed. Now the whole ISP and Broadband providers temporarily solved the problem. Soon the problem will be fixed with a permanent solution. Then you will get your normal and maximum speed of 256 KBPs. Thanks
