Living in haryana come at its own cost , i asked the Airtel technician that is working at my home " that i want to have NAT TYPE 2 instead of NAT TYPE 4 " the main guy they were calling supervisor said "haan bhaia ye ipv4 hi hai "
That's the same case with Airtel technicians in general or any major ISP. The so called "engineers" are trained to splice fiber and get the connection up and running. Zero technical knowledge.
Better to get a static IP from Airtel because their IPv4 is under CGNAT. You won't get NAT Type 2 with CGNAT.
PS: Bridge mode can only be enabled from Airtel backend team. You need to request it separately by sending an email to net@airtel.com
@_rajat I might be wrong , but i saw on reddit that different static ip from different regions take different routing routes to eafc 26 mumbai servers . So when asking for static ip's should i mention to the airtel support team that i want better routing to mumbai servers? So they can assign me a static ip accordingly....
I am not sure if that is possible. Static IP is assigned randomly and the BNG is nearby only. For example, my static IP on TPF shows IP location as mumbai but I never faced any issue wrt browsing or ping. Infact ping on valorant and CS2 reduced by a couple of ms after switching to static IP.
A public IP will automatically get you to a type 2 NAT. Just make sure to open specific ports required for your server.
I can still login to excitel admin . May be i already enabled bridge mode and disabled tr-609 client and that’s why they were unable to update my ont password lol
