Guys hello My 2500 ul plan time limit is over So which plan should i opt for ?Are there any one else providing better 3G here as 4500 100GB Plan is good as 45 / gb but then after only 100GB for 6 MONTHS !Wht should i do will need ur help and suggestions
i don't think there is any other plan/service provider who would give you 100gb for 6months not till now...if it was a week earlier you could have gone for 2500unlimited for 2months now it is 100gb for 2months
Yes, mate. It was at same place. I am using Bigpond 3G router. I even checked other network sim in it and works fine. Speeds got back to normal on 10th Dec 2012 for say less than half hour, then got the same speeds and even worse now. Not even reaching 100 kbps now. Data remaining is 380 gb but won't be of any use if this continues for long time.I even checked with BSNL 3G, it works fine at my area. So maybe some capping on my number specifically. Dunno whom to contact now to get this resolved?
Yea...my speeds were also back for a hour or so..and got back to shitty!!
I'm again hooked to BSNL Wired BB..
Which wired BB plan you use? What speeds?
BSNL broadband...750 bucks 1Mbps till 6GB then 512Kbps..But i'mm getting 1Mbps even after crossing 6GB!!
Did you call the MTNL guy..did you ask about the speeds??
I called him..but he is saying the problem is present in my end..but i did test my BSNL 3G connection its working flawlessly...
