Hello guys.....
I am frustrated user of the MTNL triband....
I am using it from 1 yr , but from last 3 mnths i am facing frequent disconnection. N Now its not even getting connected. I am using parallel line for telephone and router (UT 300 R2U) . After i start facing this problem, I used to disconnect the parallel line and use the line from the splitter for the telephone. But still it didn't work.
Here is my observation from the DSL Status section of 192.168.1.1
When Connected
downstream upstream
Rate(kbps) 2047 263
SNR margin(db) 6.8 24.0
Attenuation 46.5 31.9
Output power -6.4 96.3
super frames 5726 5724
Super frame errors 1006 40
These days I dont even get the connectivity. The Link LED glows for 4-5 seconds, then Data led glows for a second and both goes off. Again the same thing.
Please help me figure out the problem. Is the problem with Modem or Line or Configuration.
Thanks in advance..
When Connected
downstream upstream
Rate(kbps) 2047 263
Thanks in advance..
