Need Help bypassing Jio DPI using rooted ont
  • Thread starter Thread starter naitik1203
  • Replies Replies 17
  • Views Views 231
Lucknow
Jio
I have a JF rooted ont (model JCOW411), and I want to completely bypass Jio DPI, I tried using VPN services like cloudflare warp but they throttle speeds. (They means Jio not cloudflare).
I already have AdGuard Home running on ONT acting as both dhcp server and dns server for all devices connected on ONT but it only manages the DNS querries JF dpi is more than that.
goodbye dpi is useless here and never works tried using zapret but again pages like olx started bufferring too much
try this ,this should help.
/sarcasm
I cannot disconnect it there is no other service provider in my apartment due to some illegal contract between Builder and Jio.
No other operator gets access of building premises other than Jio for fiber and airfiber is not good for low latency tasks.
try using zapret2 maybe?
Please give me the exact commands to use as using basic flags like this one winws.exe --wf-tcp=443 --filter-tcp=443 --dpi-desync=multidisorder --dpi-desync-split-pos=1,midsld --dpi-desync-fooling=md5sig,badsum --new --filter-udp=443 --dpi-desync=udplen --dpi-desync-any-protocol=1 works on windows pc but does not when using nfws on ONT
I'd like to understand a few things, so if there is a better solution, we can work with that.
  • What is the problem you are having that needs bypassing DPI?
  • Do you understand how DPI works and where it is set up?
  • What does DPI have to do with "Some apps like flipkart stop showing pages like my card, account, etc."?
  • What do you mean by Jio throttling Warp? How did you experience this, or what problems did you see?
  • What does DPI has to do with rooting your ONT?
there isn't much you can do about DPI in Jio fiber ,since i had it for only 3 months back in May 2023 and the experience was slower than my DOSCIS Hathway broadband connection
Instagram photos loaded slowly, Youtube thumbnails loading slowly, images on websites loading slowly.
I tried to use Mullvad VPN back then to try mitigating this but it didn't really help much
