Need help Downgrading c2110 for Port Forwarding
  • Thread starter Thread starter cypherking
  • Replies Replies 13
  • Views Views 3,146
Port Forwarding Call of Duty 4 on the Nokia Siemens C2110 - PortForward.com
I read that, whether I use Protocol/Type - UDP or ALL it doesnt matter..
The only difference in using ALL is that if I use ALL, I have to only add a single rule with ALL in Protocol/Type -- It doesnt use the port values given-- and all the ports will be opened...
If I use UDP i have to add rule all three rules individually.
But anyways..
Uncheck "PPPoE" and select "bridged" [COLOR=#475E8C !important]Apply[/COLOR] Save REboot
In same [COLOR=#475E8C !important]website[/COLOR] " dialer " set up is given.
Did you try from another system/computer ?
Thank you that worked perfectly....I can now see my server on xfire with an external ip :Boy Yahoo:.
the dialer software I assume is the PPPoE client? it didnt install..i had setup a connection manually but it worked.
I have uploaded the firmware versions V55.1.04.02 & V55.1.04.10 on medifire acc. if anyone may need in the future
Here is the link firmware_c2110.zip
But anyways..
Congratulations.
NO portforwarding needed if you use Dialer and connect to Internet !
Al ports are open ( Use Firewall and AV applications !!)
If you open the menu pages PF menu will not be seen !!! confirm.
Thanks for the upload. noted for future use.
