So the ONT (AK telecom) provided from BSNL franchise though is average with good WiFi signals but I received a message from BSNL saying "the ONT connected to my landline number is not secured and is vulnerable to security attacks. Kindly change the ONT to avoid disconnection". I'm aware of a few ONT's like Digisol, Syrotech, Netlink etc compatible with BSNL ftth. My requirement is a good quality ONT with a good WiFi strength at least on one floor as I plan on using another router as extender on the above floor (connected via LAN cable). A single band ONT should suffice my need for a 100 mbps lineI have read reports of a few Syrotech & Digisol single band ONT's hang & lag quite a few times, so I was wondering which one to go for.
Does TP-Link manufacture single/dual band ONT's compatible with BSNL ftth?
If possible kindly provide links to the ONT you suggest.
Please advice and thanks for reading.
